Ran over puddle engine stalled later that night?
OBERT101
  • 1997 FORD ESCORT
  • 4 CYL
  • 140,000 MILES
Pretty much I ran over a huge puddle of water. I got home parked it. Went to leave it started right up got about a mile down the road and it just stalled. No pop. No smoke just dead. Its been sitting for a little over a month. I got it towed today and a lot of water came out the tailpipe. It will crank but no turn over. Any ideas
Monday, February 9th, 2009 AT 2:18 PM
SQM
  • 6,383 POSTS
First you need to change the oil and filter of the vehicle.
Since you have stalled in water, you possibly have water in the engine. It likely got sucked thru the intake. By changing the oil you will be able to make sure there is no water in the engine.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Also it will be a good idea to clean out the Mass air flow sensor and the throttle body.
https://www.2carpros.com/articles/mass-air-flow-service
Also you need to check for any codes. This can narrow down the issue:
https://youtu.be/vMwTzURWXmk
Sunday, August 1st, 2021 AT 8:48 PM
