1997 Ford Escort 5th gear acceleration hiccups
ORANGEMOO23
  • 1997 FORD ESCORT
  • 4 CYL
  • MANUAL
  • 150,000 MILES
Hi, I own a '97 ford escort which is getting up in mileage. I commute roughly 90 miles a day, and have been recently experiencing trouble when in 5th gear and accelerating past 50 mph. It seems that when I keep my foot on the accelerator at a constant rate or try to accelerate for any period of time, the engine feels as though it hiccups or almost as though it has a momentary lapse where it may stall out, but doesn't stall. I also noticed that once into the 5th gear, my speedometer is useless and bobs up and down never giving me an accurate speed reading. I tried replacing the spark plugs and wires, but that didn't seem to help. The engine in the car was replaced roughly 75,000 miles ago. Any suggestions or ideas on what I should try next?
Friday, July 16th, 2010 AT 7:28 AM
  • 109,885 POSTS
The speedo is run by a vehicle speed sensor (VSS). That is where I would start with that problem. As far as the engine, have you checked fuel pump pressure? Was the fuel filter replaced when the tune up was done? Any vacuum leaks?
Monday, July 19th, 2010 AT 12:26 AM
