1996 Ford Escort Lost performance when gas tank under half
1996 FORD ESCORT
109,000 MILES • 4 CYL • FWD • AUTOMATIC
BLYR1020
The timing belt broke and fuel pump went out. Both have been replaced and car runs good. However, when gas tank gets below half full, car bogs down when turning corners. Acts like it is starved for fuel. Fill the tank up and there is no problem.
Jan 4, 2009 at 1:55 PM
BMRFIXIT
  • 19,053 POSTS
I would remove and recheck the fuel pump
make sure I have the correct fuel pump installed and its secured on correctly
Jan 4, 2009 at 2:20 PM
WINGNUT74
  • 14 POSTS
My 97' Escort is experiencing the same issues, "Loss of Power when making right hand turns, when my tank is less than 1/2 full" Did you happen to correct this problem with your car, and if you did, Can you please tell me what you found was the problem.
Thanks,
Wingnut74
Feb 12, 2009 at 3:50 AM
