1995 Ford Escort Possible relay out?
1995 FORD ESCORT
09EMDOG
  • 35 POSTS
Electrical problem
1995 Ford Escort 4 cyl Automatic 192000 miles
i have a 95 ford escort and i replaced the climate control moduale through a local junk yard so im not 100% possitive it works 100%. but anyways when i turn on the air or heat i only get a lil bit of air out of the front dash or floor or even the defrost. i was wondering what could be the problem a defective relay or doors for switching sticking i already know where the switcher is located (i also tried switching from panel to defrost from switcher located on passenger side floor)
Aug 31, 2010 at 7:19 PM
  • 110,240 POSTS
Is the problem air flow direction or lack of air flow?
Sep 2, 2010 at 3:45 AM
09EMDOG
  • 35 POSTS
its not the direction when i turn the twist nob for the amount of air it shuts off at 3 and 4. 1 and 2 run fine.
Sep 2, 2010 at 6:53 AM
  • 110,240 POSTS
Replace the blower motor resister. That should take care of the problem.
Let me know if it works for you.
Sep 2, 2010 at 3:57 PM
