1995 Ford Escort Slow Start After Sitting
Suggested Repair
Treat this as a fuel-pressure issue first. Inspect the fuel lines from the tank to the injector rail for leaks or kinks, replace the fuel filter if its service history is unknown, and add fuel-injector cleaner. If the delayed start continues, test fuel pressure against specifications. Investigate the ignition system only if fuel pressure is within spec.
Conversation Summary
A 1995 Ford Escort with under 60,000 miles takes several seconds to start after sitting about 30 minutes or more, and sometimes needs a second attempt. It starts immediately if the key is left in Run/On for a second or two, and restarts normally for a while afterward. A new battery, spark plugs, and plug wires made no difference. The expert said the key-on delay points more to fuel delivery than ignition, because turning the key on powers the fuel pump and builds pressure. Recommended steps are to inspect the fuel lines, change the fuel filter if needed, use injector cleaner, and then test fuel pressure. The owner asked whether residual pressure would explain the successful second start, but no further reply is shown.
