Timing belt timing?
BAM710
  • 1994 FORD ESCORT
  • 4 CYL
  • FWD
  • 100,000 MILES
Timing belt slipped off I need to replace the timing belt?
Sunday, November 2nd, 2008 AT 6:30 PM
OBXAUTOMEDIC
  • 3,711 POSTS
In order to fix your timing belt you will need to take the front of the motor apart. I would suggest replacing all timing components and the water pump while in there.
https://www.2carpros.com/forum/automotive_pictures/188069_94escorttimimg_1.jpg
Sunday, November 2nd, 2008 AT 7:06 PM
BYRON1151
  • 1994 FORD ESCORT
Engine Mechanical problem
1994 Ford Escort 4 cyl
how to replace a timing belt
Monday, September 28th, 2020 AT 10:51 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
here is the removal instruction along with diagrams....
I will also email the removal istructions...
https://www.2carpros.com/forum/automotive_pictures/188069_94escortremovinstruct_1.jpg
https://www.2carpros.com/forum/automotive_pictures/188069_94escorttimimg_2.jpg
https://www.2carpros.com/forum/automotive_pictures/188069_94escorttimimgtension_1.jpg
DON OLIVER
  • 101 POSTS
Don't you just love the way the diagrams make it look like you got all the room in the world to work? That is how it's done tho. Good pictures and info.
JPLETCH
  • 1994 FORD ESCORT
  • 4 CYL
  • MANUAL
  • 200,000 MILES
The timing belt broke going down the highway at 65mph what are the chances that it bent a valve and how if it didnt do you set the timing on the car?
Monday, September 28th, 2020 AT 10:52 AM (Merged)
DAVE H
  • 13,384 POSTS
I'm 99% sure you have bent valves ... sorry
REMOVAL & INSTALLATION
TIMING BELT
Removal
Disconnect negative battery cable. Remove accessory drive belt and automatic tensioner. Support engine with floor jack. Remove engine mount at timing belt end of engine.
Remove 2 engine mount-to-bracket bolts. Loosen engine mount through bolt. Rotate engine mount out of way. Remove retaining nuts and timing belt cover.
Rotate crankshaft and align timing mark on camshaft sprocket with timing mark on cylinder head. See Fig. 1. Ensure crankshaft sprocket timing mark aligns with oil pump housing timing mark.
Loosen belt tensioner retaining bolt. Pry belt tensioner away from timing belt and tighten retaining bolt. See Fig. 2. Install mount at timing belt end of engine to support engine.
Remove spark plugs. Raise and support vehicle. Remove retaining bolt and crankshaft damper. Remove timing belt.
CAUTION:DO NOT rotate crankshaft or camshaft with timing belt removed.
If removing camshaft sprocket, remove retaining bolt and camshaft sprocket. If removing crankshaft sprocket, pull sprocket from crankshaft.
CAUTION:DO NOT rotate crankshaft or camshaft with timing belt removed. If camshaft must be rotated, install crankshaft pulley and position crankshaft with cylinder No. 1 at 90 degrees BTDC.
Fig. 1: Aligning Camshaft & Crankshaft Timing Marks
Courtesy of FORD MOTOR CO.
Fig. 2: Releasing Timing Belt Tension
Installation
Install camshaft sprocket if removed. Tighten retaining bolt to specification. See TORQUE SPECIFICATIONS.
Install crankshaft sprocket if removed. Install timing belt over sprockets in counterclockwise direction, starting at crankshaft.
CAUTION:Maintain tension on timing belt between crankshaft and camshaft sprockets when installing belt over remaining sprockets.
Loosen belt tensioner retaining bolt. Allow belt tensioner to apply tension on timing belt.
Rotate crankshaft 2 full revolutions clockwise and realign timing marks. DO NOT rotate crankshaft counterclockwise. Tighten belt tensioner retaining bolt to specification. See TORQUE SPECIFICATIONS.
To install remaining components, reverse removal procedure. Tighten bolts to specification.
this diagram is for ford escort LX
https://www.2carpros.com/forum/automotive_pictures/266999_timing_1.jpg
JPLETCH
Thank you so much for a reply. You have no idea how much it means to me. Thank you
DEB FLEETWOOD
  • 1993 FORD ESCORT
1993 Ford Escort 4 cyl Two Wheel Drive Automatic
I changed the timing belt and now it won't start.
  • 109,885 POSTS
Are you getting spark and fuel to the engine? Are you certain that the timing was correct when you replaced the belt?
VINNY600
  • 1993 FORD ESCORT
  • 4 CYL
  • MANUAL
  • 870,000 MILES
Hi I have a ford escort 1.8 16 v xr3i with the twin cam zetec and have replaced the twin cams but when putting it cams back on the head have now found out that theres timing marks on the cams is there anyway of telling how the cams are meant to sit by the way the loabs are sitting
MERLIN2021
  • 17,250 POSTS
Put the timing gers on as shown...
https://www.2carpros.com/forum/automotive_pictures/62217_18TimMarksa_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_18TimMarksb_1.jpg
I think the bottom pulley shown here is actually the crank!
JDRIVE
  • 1993 FORD ESCORT
Need to know how to align the crank shaft and cam gear have a 1.9 four cyl engine with 105,000 miles
MERLIN2021
  • 17,250 POSTS
Here's a few diagrams to help, remember, dont rotate the engine with the old belt removed! Align marks first, crank mark aligns with oil pum mark, cam aligns with cyl head mark...
https://www.2carpros.com/forum/automotive_pictures/62217_19Timming_Belt_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_19Timming_Marks_1.jpg
CRAIGFL
  • 89 POSTS
Your advice seems to be for the 1.9L but I'm not sure why Ford tells you NOT to rotate the engine with the belt removed since this engine is of the non-interference type. In fact, if he broke the belt, the engine and/or cam pulley must be rotated to align the two.
MERLIN2021
  • 17,250 POSTS
That may be true, but if it is an interferance motor, you would remove the rocker arms first.
BLESSEDLUVSCHUCK
  • 1992 FORD ESCORT
1992 Ford Escort
how do I time the cam. Related to the TDC. Timing belt stripped out. Teeth stripped. Cam and valves are not timed to the TDC of #1 piston.
DAVE H
  • 13,384 POSTS
Have you checked no valves are bent before you re-time the vehicle ???
Installation
To install remaining components, reverse removal procedure. Tighten bolts to specification. See TORQUE SPECIFICATIONS.
https://www.2carpros.com/forum/automotive_pictures/266999_tim_2.jpg
https://www.2carpros.com/forum/automotive_pictures/266999_tim2_1.jpg
Application.................................Ft. Lbs. (N.m)
A/C Compressor Mounting Bolt.......15-22 (20-30)
Belt Tensioner Bolt.......................17-22 (23-30)
Crankshaft Damper Bolt.................81-96 (110-130)
Power Steering Pump Bolt.............30-45 (40-62)
Water Pump Bolt..........................15-22 (20-30)
.................................................INCH Lbs. (N.m)
Timing Belt Cover Nut.....................44-62 (5-7)
Valve Cover Bolt.............................44-106 (5-12)
MATT 509
  • 1990 FORD ESCORT
  • 4 CYL
  • FWD
  • 128,456 MILES
How do I get the car in time? Took off the timing belt, where do I need to line the marks up?
BMRFIXIT
  • 19,053 POSTS
Check this out
good luck
https://www.2carpros.com/forum/automotive_pictures/99387_escort_3.jpg
MSELL61
  • 1985 FORD ESCORT
  • 4 CYL
  • 100,000,000 MILES
Timeing marks on 85 ford escort with 1.5describe your problem.
Monday, September 28th, 2020 AT 10:53 AM (Merged)
