1994 Ford Escort rotor
RALPHSCOTT10
  • 1994 FORD ESCORT
Brakes problem
1994 Ford Escort 4 cyl Front Wheel Drive Manual
my drivers side front rotor is loose and I cannot figure out how to tighten it can you help
Monday, November 17th, 2008 AT 2:41 PM
DAVE H
  • 13,384 POSTS
FRONT BRAKE ROTOR
Removal & Installation
Remove front wheels. Remove front brake caliper and pads. If caliper does not require service, removing brake hose from caliper is not necessary.
Using mechanic's wire, secure caliper out of way. Remove rotor from hub assembly. To install rotor, reverse removal procedure. Bleed brakes (if necessary).
If rotor is stuck on hub. Lightly tap it all the way round the centre as you turn it and pull it off hub
Monday, November 17th, 2008 AT 3:09 PM
