1994 Ford Escort No Brake Lights
JOHN CASPER
  • 1994 FORD ESCORT
Electrical problem
1994 Ford Escort 4 cyl Front Wheel Drive Automatic 165K miles
I have no brake lights, although the 3rd stop light within the car does work.
I checked the fuses under the dash, all OK.
I Cheched the main fuses under hood, all Ok.
So what could be wrong? Is there another set of fuses I'm overlooking? I don't have the car manual.
Please offer suggestions.
John
Sunday, April 19th, 2009 AT 11:14 AM
EDALEJ50
  • 11 POSTS
You said your 3rd brake light work. So that means fuse and your brake light switch is also working. Possibility is, either you have a burnt brake light bulb or open circuit down on your brake light housing or a corroded one.
Sunday, April 19th, 2009 AT 11:25 AM
