1994 Ford Escort central locking
1994 FORD ESCORT
96,000 MILES • 4 CYL • FWD • MANUAL
PAULCHENEY1385
hi when i lock the doors to put the alarm on it works fine but when i unlock the car all the doors open apart from the drivers door i can only open the door if i get on the car and lock the door from the inside then unlock it again and the door will open if you have any segestions on how to solve this it would be great thanks alot paul
Aug 29, 2009 at 6:44 PM
LAZYGAZER
  • 68 POSTS
Does this car have a factory installed alarm with door lock unit or aftermatket unit?
Aug 30, 2009 at 10:52 AM
PAULCHENEY1385
HI IN REPLY TO YOUR QUESTION IT IS ORIGANAL FORD FITTED ALARM THAT CAME WITH THE CAR TO LOCK TURN KEY TO LOCK TO SET ALARM TURN KAY TO UNLOCK THEN LOCK AND THE ALARM BEEPS
Aug 30, 2009 at 12:25 PM
MIKESMECHANICAL
  • 6 POSTS
Your problem is most likely a problem with the power door lock actuator, the style used in these vehicles will bind and work to lock but not unlock, or vice versa. Occasionaly you can lube the threaded rod located on the top of the actuator (under the rubber protective cover) use a silicone type of spray.
Aug 30, 2009 at 12:56 PM
PAULCHENEY1385
hi thanks for your awnser could you tell me where the door lock actutar is please
Aug 30, 2009 at 1:26 PM
MIKESMECHANICAL
  • 6 POSTS
First you need to remove the door panel the actuator should be located under the latch assy, it will have a 2 wire connector and will be attatched to the latch with a rod, be careful when moving things around, the rods are attatched with plastic clips which will be brittle on a car that old. once you locate the actuator pull up the rubber sheild, spray the lubricant on the threaded rod under it if possible lock and unlock the door while spraying to dispurse it into the threads. Good luck, take your time.
Aug 30, 2009 at 1:33 PM
