1993 Ford Escort Transmission
HOMEBOY23834
  • 1993 FORD ESCORT
1993 Ford Escort Front Wheel Drive Automatic
When I apply brake transmission does not release out of park.
Tuesday, November 4th, 2008 AT 4:12 PM
DAVE H
  • 13,383 POSTS
Sounds like it could be a problem on the BOO switch (brake on/off) and the car is not getting the correct signal when you press pedal ? Try shifting manually with the ignition on but the engine not running? Does this work? Without knowing the exact model of vehicle I can't help further i'm afraid. There are different gearboxes depending on engine size?
Sunday, November 9th, 2008 AT 7:53 AM
