1993 Ford Escort maxi fuses
1993 FORD ESCORT
122,469 MILES • 4 CYL • 2WD • AUTOMATIC
HIGHROLLER619
how do i check maxi fuses and and fusible links and where are they located?
Sep 7, 2010 at 8:28 PM
WRENCHTECH
  • 20,761 POSTS
Please stop opening new questions. Simply respond to the original question.
The fusible links run off the starter solenoid, near the battery. the maxi fuses should be in the engine compartment fuse box.. It may only have one or the other. Fusible links are special melting wire. Pull on each one and see if they stretch. For the fuses, an ohmmeter works best.
Sep 7, 2010 at 8:42 PM
