1993 Ford Escort AUTO TRANSMISSION MALFUNCTIONS WHEN WARM
LORRAININSPAIN
  • 1993 FORD ESCORT
  • 6 CYL
  • FWD
  • 82,000 MILES
I HAD A TRANNY LEAK AND MECHANIC TIGHTENS THE BOLTS ON PAN UNDERNEATH. NOW THE GEARS DON'T WANT TO WORK. IT DRIVES ONLY WHEN TRANNY IS COLD. WHAT DO I DO?
DO I NEED A NEW TRANNY? IF SO, WILL A USED TRANSMISSION FROM ANOTHER CAR WORK? MAZDA OR SABLE I HEARD.
CAN I CHANGE THE TRANNY FLUID AND FILTER TO SEE IF IT WILL IMPROVE THE GEARS SLIPPIN?
CAN I CONVERT AUTOMATIC TO 5 SPD?
Friday, January 8th, 2010 AT 5:18 PM
DAVE H
  • 13,384 POSTS
You need to have the transmission repaired or rebuilt. We would need the transimission # to supply other makes fitted with same trans. It can be converted to manual with some extra work !
Sunday, January 10th, 2010 AT 4:49 AM
