1992 Ford Escort fast idle
STOMPINGGAZZA
  • 1992 FORD ESCORT
  • 4 CYL
  • FWD
  • MANUAL
  • 97,000 MILES
Hi the other day the head gasket went on my escort before it went its drove and run perfect now ive changed the head gasket the car idles at 1500 rpm not shure why any info would be great thanks
Thursday, April 8th, 2010 AT 11:57 AM
TOOOMANYTOYS
  • 513 POSTS
Try cleaning the idle air control valve with throttle body cleaner. Also look for any vacuum leaks.
Thursday, April 8th, 2010 AT 12:06 PM
STOMPINGGAZZA
Didnt think it had 1 as its carburetta also I took air filter box off today and noticed its got lots of oil in it again after cleaning it when I done the head gasket at that point I cleaned rocker cover and some blocked pipes but still oil in the air box but not entering the carb at all
Thursday, April 8th, 2010 AT 5:54 PM
TOOOMANYTOYS
  • 513 POSTS
Disconnect Idle Air Bypass (IAB) valve assembly connector from the wiring harness.
Remove two IAB valve assembly retaining bolts.
Remove valve and gasket.
INSTALLATION
Ensure that both throttle body and IAB valve gasket surfaces are clean. NOTE: If scraping is necessary, be careful not to damage IAB valve or throttle body gasket surfaces, or drop material into throttle body.
Install new gasket on throttle body surface and mount valve assembly, securing it with two retaining screws to71-97 in lb (8-11 Nm).
Connect electrical connector for IAB valve.
Are you sure its carburated all information I have on a 1992 ford escort is fuel injected. If it is carbed. Try turning down the idle set screw. Usually oil in air filter housing indicates blow by.
Thursday, April 8th, 2010 AT 8:50 PM
STOMPINGGAZZA
Hi its deffo carburetta its a 1.4 lx please what do you mean by blowby and what shal I do to sort please thanks
Friday, April 9th, 2010 AT 4:18 PM
TOOOMANYTOYS
  • 513 POSTS
Blow by is when the piston rings start wearing out in the motor. Pushing engine oil fumes into the air intake through the beather. Is this an american made ford escort? If it has a pcv valve try changing that first to see if the oil issue goes away. If not you might want to do an engine compression test to see if you have low compression in the cylinders.
Friday, April 9th, 2010 AT 5:17 PM
