1991 Ford Escort how do I change a transmission filter
ZELIKIA
MEMBER
1991 FORD ESCORT
4 CYL
2WD
AUTOMATIC
75,643 MILES
How do I change a transmission filter in the 1991 ford escort please provide the steps in changing the filter. Thank you
Monday, August 3rd, 2009 AT 9:31 PM
STEVEW84
MECHANIC
Take the bolts out and have a fluid pan ready to catch the fluid. There will a filter that you can either pull out or unbolt. If it is the pull out style then after you pull it out there might be a collar still left in the hole that you have take out. Push the new filter on(if it is that style) or bolt it back up. Cleanthe mating surfaces of the pan and transmission. Put the gasket on the pan and torque to spec.
