p0430 code
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
JJEIS22
my suv has come up with this code. is this the o2 sensor? i saw there were 4 at an automotive store. where are they located?
thank you
please specify as best as possible.
May 1, 2008 at 1:52 PM
BMRFIXIT
  • 19,053 POSTS
P0430 indicates bank NO. 2 catalyst system efficiency is below threshold
bank 2 is on the driver side
check for an exhaust leak
oil contamination
cylinder misfire
If all good, you may have cat converter that is bad on that side of the engine.
May 1, 2008 at 2:15 PM
LEODAJIM
  • 25 POSTS
I recently tuned up my ‘04 Escape...new plugs and coils, a new PCV valve, new intake manifold gaskets, new fuel filter, new air filter, and I cleaned the mass air flow sensor. Along the way, I verified that all hoses and connections were good and there were no vacuum leaks. After all the work, the engine ran smooth, idle was perfect, acceleration was crisp, plenty of power. Now, a week and a half later, the engine light is on and I get the P0430 code, which states "the front catalyst efficiency is below threshold.” The Escape still runs perfect, the way it did after the tune-up. So that is making me believe that the issue is an O2 sensor, NOT the front converter. If that converter was plugged or damaged at all, wouldn’t there be a decrease in performance, even a slight difference? Like I said, the engine still runs perfect. Any advice on diagnosing the issue, or what the cause could be? Thank you.
May 2, 2019 at 10:17 AM (Merged)
MERLIN2021
  • 17,250 POSTS
the catalyst efficiency code sets when the O2 sensor behind the cat starts switching a lot just as the front sensor does. if its due to a bad sensor, it is possible. do you hear any rattles? sometimes the catalyst matetial is just worn out, this will not cause performance issues. the 02 is cheaper to fix and may or may not solve the problem. a tailpipe emissions test would tell.
LEODAJIM
  • 25 POSTS
Merlin, thank you. No, I do not hear any rattles, nothing at all. I was thinking about having a diagnostic test done while the vehicle is running. Would that pinpoint if a sensor is bad, or would the tailpipe emissions test be better? I do know the converter is very expensive, so I really hope that is ok. IF, that converter is damaged, would I risk more damage to other components, the rear cat fro example, if I let it go for a while? For money reasons, if i can wait to replace the converter, that would help. Thanks again merlin.
MERLIN2021
  • 17,250 POSTS
using a scanner that reads live sensor data in graph display can tell if the sensor is performing, using both tests is more accutate. you can wait awhile to replace cat but look online for direct fit aftermarket cat.
httt://www.rockauto.com will be cheaper than the dealer.
