2002 Ford Escape grinding noise left front
2002 FORD ESCAPE
85,000 MILES • 6 CYL • 4WD • AUTOMATIC
JACK WILLIAMS
It sounds like worn brake pads. Not so. It is possibly the cv joint. When I raise the vehicle and move the wheel back and forth it makes a clicking sound. With it in gear and tires rotating the noise seems to come from the upper joint. more of a grind sound than a clicking though.
Apr 30, 2010 at 4:49 AM
  • 110,244 POSTS
Does the sound change with the vehicle's speed?
May 4, 2010 at 3:33 AM
JACK WILLIAMS
It turned out to be the wheel bearing. Apparently the noise was traveling up the axle making it sound as if it was in the trans. Thanks for your assistance.
May 12, 2010 at 5:41 AM
  • 110,244 POSTS
Glad you found it. They can be a pain to identify. Let us know if you have questions in the future.
May 13, 2010 at 12:36 AM
