You should see the rpm in the tach dial,I bet the nidle shows less than 500 rpm(200-300).The throtle plate has a cable connect it with the gas pedal.Look for the screw that regulate the position of the plate,just turn this screw clockwise three quarters of a turn allowing the idle run at higher rpms.
Tell me if it helped you.
Mar 7, 2010 at 2:57 PM
