2001 Ford Escape More problems after changing a shifter cab
2001 FORD ESCAPE
124,123 MILES • 6 CYL • 2WD • AUTOMATIC
OLDBAT1961
I changed the shifter cable that runs from the column to a lever on the transmission. After replacing the part the odometer doesn't work, the speedometer doesn't work, the o/d light flashes, after the transmission shifts into o/d and the check engine light is on. The vehicle runs and drives fine and shifts fine. I just have these idiot lights now and ideas.
Aug 14, 2010 at 3:28 PM
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Aug 14, 2010 at 4:08 PM
