transmission fluid in the radiator
FORD E-SERIES VAN
DOUGHBOY77831
i have a ford e-100 with the inline 6 the odometer has 89,000 miles i have transmission fluid going into the radiator i changed the radiator it's brand new i started the van and drove it and the dip stick blew out and sprayed transmission fluid everywhere and it caught on fire i got the fire out before it could mess anything up transmisson fluid was still in the radiator what can i do? can you help
Nov 7, 2007 at 10:51 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e836453bba="doughboy77831"]i have a ford e-100 with the inline 6 the odometer has 89,000 miles i have transmission fluid going into the radiator i changed the radiator it's brand new i started the van and drove it and the dip stick blew out and sprayed transmission fluid everywhere and it caught on fire i got the fire out before it could mess anything up transmisson fluid was still in the radiator what can i do? can you help[/quote:e836453bba]
It’s a tranny problem very high pressure you should investigate the cause
Is it return line or internal tranny failure
Good luck
Nov 7, 2007 at 11:16 AM
