1999 Ford E-Series Van Brake pedal good, then goes spongy
1999 FORD E-SERIES VAN
DAMERON
Brakes problem
1999 Ford E-Series Van 6 cyl Two Wheel Drive Automatic
I replaced the master cylinder, but still has the same
symptom: Has good pedal with engine off, turn it on,
and press, and suddenly drops an 2 inches and goes
spongy. Still stopping, but - not good.
Aug 11, 2010 at 6:27 AM
MADMIKE1735
  • 951 POSTS
bear with me on this, i believe you have drum brakes in the rear, along with rotors in the front right???? also, on the master cylinder, does your fluid reservoir have a flat, rectangle cap which when removed has 2 spots in the reservoir, or does it have a round cap??? being a 6cyl, im assuming this is an e-150... i know these vans fairly well, so let me know what setup you have, and we will have you fixed in no time.
Sep 17, 2010 at 12:43 PM
