1997 Ford E-Series Van no heat
111,960 MILES • V8 • 2WD • AUTOMATIC
BIGFORDVANFAN
i replaced the termoastat flushed the coolant upper radiator hose gets hot lower hose is cold heater core getting hot coolant but still no hot air through the vents
Nov 19, 2008 at 8:23 AM
  • 110,248 POSTS
Hi:
Does the engine run at a normal operating temp? Also, it's unusual that the lower rad hose stays cool. It should be hotter than the top. Coolant works it's way up through the radiator to cool. If it dropped down, it wouldn't have time to cool before going back into the engine.
Are both heater core lines getting hot and does the engine run at a normal operating temp (around 200 degrees)?
Dec 4, 2008 at 1:04 PM
JBRAUWN
Found proble, blend door is stripped out, so the actuator moves as it should but but door does not open or close. Simple issue I overlooked. Ordered new blend door an drew will have proper heat soon, as for now I have the door propped open which Work's until my door comes in he mail!
Dec 11, 2017 at 11:50 AM
  • 55,649 POSTS
Good find BTW, let us know what happens.
Cheers, Ken
Dec 17, 2017 at 5:20 AM
