1995 Ford E-Series Van engine hesitation
135,000 MILES • V8 • 2WD • AUTOMATIC
JTPERFETTI
Broke down, Engine just cut off, had it towed to Firestone, diagnosis... fuel pump. had it towed again to my nephew. He changed the pump. then hesitates and sometimes stalls. Changed fuel filter. Same, no change. Just gased up with premo gas and additive. no change. what can i do next? And what is the extra fuel pressure for this van?
Feb 16, 2010 at 3:50 AM
2CARPRO JACK
  • 11,533 POSTS
Would have to know engine size for fuel pressure spec.Did you use a high quality pump or a less expensive one? The cheaper pumps are exactly that...cheaper.I have had to remove many less expensive pumps for performance problems, and install OEM pumps.Let me know what engine then you can double check fuel pressure to be sure it is in spec
Feb 17, 2010 at 12:19 AM
JTPERFETTI
I will ask my nephew re: what fuel pump he bought.
Feb 17, 2010 at 1:48 AM
2CARPRO JACK
  • 11,533 POSTS
ok let me know.Also ask him if it was hesitating before the fuel pump died
Feb 17, 2010 at 8:54 AM
