1991 Ford E-Series Van rear air
1991 FORD E-SERIES VAN
RODNEY290
Air Conditioning problem
1991 Ford E-Series Van V8 Two Wheel Drive Automatic
I have a 1991 ford conversion van i just bought it has vents for rear air in the back above the rear seats the rear speakers are also in the same console.There is a switch that says rear fan underneath on the drivers panel that has 5 speeds.The fan does not work there is no air coming from the rear vents.could you tell if the vents run off of the same blower fan as the front vents or if they have a seperate blower and where it might be located any info you can give me wold be appreciated.Rod
Jun 20, 2010 at 5:26 PM
2CARPRO JACK
  • 11,533 POSTS
The rear air has its own blowe rmotor.It will be located behind the interior trim on either the right or left side all the way in the back.If you look under the van, you will be able to see which side the A/C and heater lines go to.Once you see which side, you will have to remove the side panel to get to it.
Jun 22, 2010 at 8:07 AM
