Missing Ford
FORD CROWN VICTORIA
J41LA
I have a 1993 Ford Crown Victoria LX. I've been having problems with it stumbling and hesitation. I brought it to a parts place on 4 separate occasions to get the PCM diagnosed. And they would give me printouts. EGR Sensor-Below Min Voltage,,,EGR Flow Insufficient,,,EGR Sensor-Above Max Voltage... I was told it wasn't the EGR Sensor, because a bad sensor wouldn't make the car run bad. So i'm thinking maybe the EGR Valve..Thanks.....
Jan 13, 2006 at 5:55 PM
PALCO
  • 83 POSTS
ya replace the egr, and probaly the o2 sensor as well. just a thought. good luck
Jan 14, 2006 at 12:26 AM
IECARL
Had similiar problem with a 93 crown vic. Ford company charge me a fortune and did no good. Finally found problem when changed plug wires and plugs. Know this doesn't sound like a solution to your problem, didn't think it would solve mine, but it worked. Just a thought to help you out.
iecarl
Jan 14, 2006 at 10:07 AM
