2001 Ford Crown Victoria fan motor is out
GAR1118
  • 2001 FORD CROWN VICTORIA
  • V8
  • 181,000 MILES
I have power to the fan motor but does not work. How do I change & or what is the avarage cost for it to be changed. I will donate if I get an answer that looks like it will help
Tuesday, October 5th, 2010 AT 7:10 PM
WAY2OLD
  • 195 POSTS
If there is power at the blower motor connector, the blower needs replaced. It is fairly easy to replace. Unplug the connector, remove the little bolts that hold the blower in. ( I think there are 5 or 6 of them) Remove the blower. There is a small clip that holds the blower cage on the motor. Take the clip off, tap the blower shaft whild holding the cage. The blower should come off. Install cage on new blower, install in housing, install bolts and hook up wiring. Good luck.
Wednesday, October 6th, 2010 AT 6:03 PM
Related General Content
