2000 Ford Crown Victoria failsafe cooling light
CDWADE
  • 2000 FORD CROWN VICTORIA
  • V8
  • 110,000 MILES
This is possibly an electrical problem. Not sure.
Yesterday I pressure washed the engine. Today, it has a problem. It runs fine while idling. The minute you accelerate, the cooling light flashes on and the car dies. It recranks easily and idles fine. What have I gotten water into, as that seems the most likely problem as it didn't do this before the cleaning.
Tuesday, June 23rd, 2009 AT 8:22 AM
WAY2OLD
  • 195 POSTS
Oun have gotten water in the spark plug well and the coil ism shorting out. You can have the codes read ans]d it will tell you the plug thyat is misfiring and causing the problem. Po301 is #1 cylinder all the way up tu P0308 for # 8 cylinder.
Tuesday, July 14th, 2009 AT 7:35 PM
