2000 Ford Crown Victoria Battery Replacement
2000 FORD CROWN VICTORIA
ABUTAHA
Electrical problem
2000 Ford Crown Victoria V8 Automatic 130000 miles
My fully-loaded Ford CV needs a new battery. The current one has the battery with a 750 ca charge capacity (part no. BXT-65�750) whereas the batteries available currently where I am hold either a 675 ca charge or an 850 ca charge. If I install the 850 ca battery, will it cause any damage to the car? Alternatively, will the 675 ca be enough for all of the electrical features/options of the car to function properly?
Aug 18, 2010 at 2:27 AM
WRENCHTECH
  • 20,761 POSTS
Your car requires a minimum of 750 will the accessories it has. It's always a good idea to use larger than required. The battery will always have enough reserve and won't fail as quickly.
Aug 18, 2010 at 2:51 AM
