2000 Ford Crown Victoria 4.6 L 99000 miles
CLINTON
  • 2000 FORD CROWN VICTORIA
Obd 2 code reader says sylinder 6 misfire, what do I do to fix it? The car jerks a little sometimes and the check engine light comes on and sometims flashes. I changed the spark plugs and it still does it, IM guessing that its probably the fuel injector but not sure. If so how much would one be for this car.
Thursday, January 25th, 2007 AT 11:58 PM
SERVICE WRITER
  • 9,123 POSTS
The check engine light flashing means there is damage being done to the converter, like excessive fuel not being burn't. ORiginal wires?
You can try swapping two wires to see if the misfire moves to the other cylinder, same on the fuel injector-1 test at a time.
I'm not so much sold on the injector at this point. Air induction service may be a potential solution as well. Get the ignition wire question out of the way first.
Friday, January 26th, 2007 AT 5:04 AM
2CARPRO JACK
  • 11,533 POSTS
Hey Paul im gonna chime in on this one, does it have individual coils? If so then do as Paul suggested, but move the coil to another cylinder. Oddly enough it seems to be almost an even split on coils and injectors in Fords. Dont ask me why
Friday, January 26th, 2007 AT 7:27 AM
