1999 Ford Crown Victoria hey my car is like missfiring
ELLIOT.WEBB1
  • 1999 FORD CROWN VICTORIA
Engine Performance problem
1999 Ford Crown Victoria 4 cyl Automatic 135000 miles
my? Is whenever I start to drive my car I start off idling at a slow rate then it kicks in its quiet somtimes then it starts tapping but a mechnic told me that its missfiring what do I need to and with 135,000 what type of oil do I need to use because I was told high milege would work
Tuesday, October 14th, 2008 AT 8:49 PM
MUSTANG87
  • 261 POSTS
Most of the time its a bad plug wire. Have you ever changed the plug wire set?Also can be bad plug spark. Just tune it up with new wires and plugs and miteaswell air filter and fuel filter. You should be ok.
Tuesday, October 14th, 2008 AT 10:00 PM
RICK 08
  • 54 POSTS
Elliot Hi : I am not sure I can help you with the info you submitted:
For what it is worth.
Please try to articulate further, be mindfull of your diction, I am having a difficult time following what you are trying to communicate.
Reguards. Rick
Sunday, October 19th, 2008 AT 10:14 PM
