1998 Ford Crown Victoria
PDUDEMAN1
  • 1998 FORD CROWN VICTORIA
  • V8
  • 215,012 MILES
How to replace a fuel tank and fuel filter
Monday, December 29th, 2008 AT 3:19 PM
  • 109,885 POSTS
Hi:
Basically all you need to do is remove the two straps holding it in place. Make sure you have it supported so it doesn't fall on you. Also, I recommend having as little gas in it as possible. Once out, you will need to remove the fuel pump and sending unit. If you have other questions, let me know.
Monday, January 5th, 2009 AT 9:35 PM
