1997 Ford Crown Victoria turns signal
1997 FORD CROWN VICTORIA
12,500 MILES • V8 • 2WD • MANUAL
SJLSANDY9
How do you fix a turn signal? Where is it? What is a fuse?
Dec 11, 2007 at 2:51 PM
HOT4RD
  • 5 POSTS
You didn,t specify the problem, if a turn signal is flashing fast on one side a bulb is out, ck the front bulb and rear bulb on the side with the problem(compare to the working side).
If the turn signals are not working at all, try pushing the hazard button and wiggling it and see if the turn signals work. I have seen many of these switches go bad. By switch, I mean the lever that you push up and down, it is a switch. Maybe this will help.
Dec 19, 2007 at 9:18 AM
