1997 Ford Crown Victoria 1997 Crown Victoria dies when put
AUSTINRC
  • 1997 FORD CROWN VICTORIA
First off let me say I'm new to this website so dont get mad at me if this was posted somewhere else I tried to find something that fit the same problem but couldn't find a thread that had the same problem. Alright so this problem started about four days ago. I was driving to work when my car shut off at a stop light. I checked the dashboard to see if the lights were still on which they were. I put the car in park then started it and it started just fine when I put it in drive again it completely died once again. I tried it again but gave it a little gas this time and barely lugged my way to work. From there I had the car towed back to my place. Every time I try and start it now it'll usually start just fine but when I put it in drive it immediately dies unless I damn near floor the accelerator. I took out some of the gasoline to see if anything had leaked into it. There was quite a bit of water mixed in with the gasoline so I took out the rest of it and filled about a quarter of a tank in with gas and Heet I got from AutoZone. The car is STILL dieing when I put it in drive. Your help is very much appreciated!
Sunday, July 11th, 2010 AT 9:34 PM
WAY2OLD
  • 195 POSTS
Sounds like the torque converter is locked up allowing the transmission to stay engaged in gear.
Monday, July 12th, 2010 AT 6:56 PM
AUSTINRC
Finally had it taken in, got it fixed apparently there was a lead cap on the battery which had corroded pretty badly. On top of that there was water in the spark plugs #7 and #8. $280 fix. Thanks for the help though guys.
Monday, July 26th, 2010 AT 10:11 AM
