1985 Ford Crown Victoria car idles high sometimes
1985 FORD CROWN VICTORIA
85,000 MILES • V8 • 2WD • AUTOMATIC
RONALD.WOERTZ
pls help my 1985 ford crown vic idles high when ever I come to a stop. When I first start it it runs fine.
thanks
ron
Jan 29, 2009 at 5:48 AM
Check and test the idle air control valve/motor and the throttle position sensor, also check the throttle plate if its binding and not fully closing/seated and also the cable not binding in the sleeve
Jan 29, 2009 at 7:42 AM
RONALD.WOERTZ
rasmataz,
Whats with not being able to view previous answers to other questions...
It makes one wonder about your answers.
Are they correct?
Thanks
Ron
Jan 29, 2009 at 9:39 PM
You should be able to view previous answered questions- If you are wondering about my answers-you see them Stars/Votes I didn't get there for nothing. If you don't mind I'll be opting and please! await for another expert to assist
There's other causes that can affect your idle than the ones I've mentioned. I choose them as prime targets before I get into the nightmare ones.
Jan 30, 2009 at 6:39 AM
