1998 Ford Courier sensor help plz
1998 FORD COURIER
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHGO_LADY01
I did step 1 with getting a system diagnostic test for check engine light.Now step 2.My dad is changing the sensors for me.The codes on the report was po136 and po156 which is the sensor b152 and b2-52.After also replacing the starter,my dad noticed a sensor next to the thermostat and starter which the sensor connects to the manifold.He thinks that is a heat sensor but not sure,is it?and not sure where the bank 1 and 2 sensor is.Supposedly there are 4 or 2 of each,have no idea.Where would these bank sensors be and how to get to it.Also,how many sensors are there in total.Are there any important ones to check out.If so,of course id say where would it be,im clueless.Thank you,you have been helpfull.Ill fill you in after this is all done.My car has many problems thankx :)
Jul 6, 2010 at 8:51 AM
BLACKOP555
  • 10,386 POSTS
id estimate around 15 sensors that are important.
can you get apicture of the one sensor your wondering about?
also bank one is the sensor on the exhaust piping that goes to the side of engine with #1 cylinder in it.
sensor 2 refers to after the catalytic convertor.
Jul 8, 2010 at 5:36 AM
