1997 Ford Contour Overheating
SPOULISSE
Have a 1997 Ford Contour SVT, 2.5L engine, 6 cyl, 120,000 miles. The engine just recently started to overheat and the inside of the car gets no warm air - checked the coolant level and added a little coolant, no help, changed the thermostat, still no help and overheating. Had coolant system flushed and was told it was probably NOT the heater core, since the system to flush it would not work if the heater core was bad? There is no coolant in the oil and we are not losing coolant, so I don't think we have a blown head gasket. Could I have a bad water pump even if we do not have a leak? Someone told my husband there is a fan inside the water pump which could be bad and it would not leak but would overheat. I also wondered if there could be a second thermo-controller? Or perhaps a fuse which may be bad?
Nov 15, 2007 at 2:26 PM
  • 75,988 POSTS
Try bleeding it see below-don't work check the fan/s and the water pump
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Nov 15, 2007 at 4:56 PM
Suggested Repair
Bleed air from the cooling system with the heater set to maximum heat, following the radiator and bleed-bolt procedure. If overheating continues, check the cooling fans and the water pump.
Conversation Summary
The owner of a 1997 Ford Contour with a 2.5L engine reports recent overheating and no warm cabin air. Adding coolant, replacing the thermostat, and flushing the system did not help; there is no coolant loss or coolant in the oil. The expert recommends bleeding air from the cooling system and, if that fails, checking the fans and water pump.
