Losing milage (150KM) on one full tanks of gas
GURMEET
  • 1915 FORD CONTOUR
1998 ford contour SE, 4 cylinder. 180 000 kms. For some odd reason I am running short on a full tank of gas. I have noticed that in the last 2 fill ups I have returned to the gas station 150KMs earlier than I normally would. There are no apparent leaks in the gas tank. Any Ideas?
Tuesday, December 19th, 2006 AT 6:33 AM
BRUCE HUNT
  • 3,754 POSTS
Anwer everyone will give you is to have the vehicle tuned up. Now that said, pull a plug out one at a time and look at them. Are they black and sooty? I would venture a guess that they are. Replace the plugs. Now dealing with the problem. Air filter, replace it. Check the timing. Are there any check engine codes available?
Tuesday, December 19th, 2006 AT 9:08 AM
