Contour, '96 LE
1996 FORD CONTOUR
MFC819
The rear brake lights don't work when stepping on the pedal. Only the middle light works. All other functions of the bulbs & switches work fine. The bulbs were replaced and fuses checked.
Jun 19, 2007 at 8:10 PM
SHELBYGT
  • 56 POSTS
check to see if you have the wires going to your lights pluged in tightly and look at the wiring were you put your brake fluid at and see if those wires are pluged in
Jul 18, 2007 at 12:44 AM
