1999 Ford Contour electric fans
CALYPSO69
  • 1999 FORD CONTOUR
  • 6 CYL
  • FWD
  • 109,000 MILES
Both electric fans turn on shortly after starting car and stay on. Today it's 20 deg out. It dose'nt matter if the air is on or off or if heat is on or off.I'm assuming there's a sensor failure but I don't know what it would be. The heat works fine and the engine gets up to temp as always. The check engine lite has been on for a long time, my mechanic thinks there's a problem with one of the four cats but the thing runs fine. Thanks
Tuesday, December 29th, 2009 AT 12:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
First check cooling fan relay(s). If OK suspect faulty engine coolant temperature (ECT) sensor. If engine codes point towards faulty catalytic converter, this would not impact the cooling fans at all.
Wednesday, December 30th, 2009 AT 1:24 AM
