1999 Ford Contour
1999 FORD CONTOUR
ERICZ
It rained heavily last night and I was travelling through it. Mad a stop and came out to start the car and went to put car in gear, but the button on the gearshift wouldn't push in even after applying the brakes. In addition, my turn signals stopped working totally. No lights on the dashboard whatsoever. My blower motor stopped working as well. These are the only 3 things that happened. I have checked all fuses and relay switches, but they are okay as far as I can tell. Are these issues interconnected? Is there mutifuses or fusible links that could cause this? what do you think?
May 10, 2007 at 4:42 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
Locats your PCM on the firewall...unplg...blow dry the connector.
May 10, 2007 at 7:21 PM
