I have recently bought my contour as is. The problem I have is that it overheats after about a mile or so driving. I've flushed the radiator, replaced the thermostat, and put a block sealer through the car. It takes longer to heat up , but it still climbs up the gauge pretty quick. Not sure if I should replace water pump and radiator or just junk it. One mechanic told me it might be a head gasket running me 2000 dollars to fix. What should i do?
May 21, 2010 at 3:06 PM
