1998 Ford Contour KEYLESS REMOTE
1998 FORD CONTOUR
103,000 MILES • 6 CYL • FWD • AUTOMATIC
RANDYDEB
I am trying to reprogram my keyless remote.
It said i need to momentarily jump pins in programming connector located behind glove box.What does this connector looks like? And do i need to take out the glove box to find this connector.
Mar 9, 2008 at 6:03 AM
MERLIN2021
  • 17,250 POSTS
Here is the revised process...Cycle ignition from off to run 8 times within 10 seconds, ending on run, not start! just "on" position. All doors will lock and unlock to confirm program mode, press ANY button on the remote, door locks will cycle to confirm a good programming, if a second transmitter is to be done just hit any button on it now!
When done programming, and you can do 4 transmitters, turn ignition to off, doors will lock and unlock to confirm...
Mar 9, 2008 at 6:10 AM
