1998 Ford Contour
VERITAS11
  • 1998 FORD CONTOUR
  • 6 CYL
  • FWD
  • 110,000 MILES
My check engine light is on and I went to autozone to have them run a test on it it came back with a code that they dont even know what it means. The code was p1518. It is making my cars rpms raise quite a bit when u turn it on and also when you are at a stop position even when the car is warmed up. It is also making my car quite loud.
Saturday, December 20th, 2008 AT 8:34 PM
  • 109,983 POSTS
Hi:
a guessing that you have a V6 Contour. The P1518, means that the Intake Manifold Runner Control(IMRC) solenoid is not moving when commanded by the PCM. The PCM knows it is not moving, because there is a built-in position sensor inside of the IMRC. The job of the IMRC is to shorten or lengthen the air flow passages into the intake manifold at the right times for maximum performance, by opening and closing ports inside of the intake manifold. These passages are moved by a cable attached to the IMRC that moves butterfly valves on shafts that run through the center of the intake. You can see the cable which will be attached to a lever and a shaft by looking right below the throttle body assembly on the driver's side of the engine. Follow that cable, and you will find the IMRC. It may even be bolted to the top of the front valve cover. Cances are you need a new IMRC. But you should clean the air intake manifold with carb cleaner to free up the butterfly valves I described. Sometimes what makes those IMRC assemblies fail in the first place, is heavily carboned up intake runner valves that cuse undue stress on the IMRC.
Let me know if this helps.
Friday, January 2nd, 2009 AT 10:58 AM
Related Check Engine Light Content
