If I may ask, were exactly is the grease coming from?
Is it behind the wheel itself?
Is it more toward the center of the vehicle?
Is it grease or could it be Oil and can you tell what color it is?
If it is the bearing you may not be able to do the repair yourself. You will need a special tool in order to press the old one out and the new one back in.
If it is more of a liquid and is more toward the center of the vehicle then it could be the CV Axle Seal. And if you aren't mechanically inclined then this could be difficult for you to do.
Wednesday, April 14th, 2010 AT 6:00 PM
