1995 Ford Contour OVERHEATS
DAVID DOSSETT
  • 1995 FORD CONTOUR
  • 6 CYL
  • 4WD
  • 40,000 MILES
ENGINE OVERHEATS VERY BADL
HAVE REPLACED THERMOSTAT
STILL OVERHEATS
Sunday, June 6th, 2010 AT 7:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure radiator fan comes on properly, check coolant level and check for coolant leaks. If all OK check compression in cylinders to see if possible head gasket or head failure has occured
Sunday, June 6th, 2010 AT 8:57 PM
