Hello nappinkat
Welcome to 2carpros. Com
You probably have a vacuum leak or fuel delivery issue.
An EGR valve that is stuck open at idle can have the same effect as a vacuum leak
Or a loose PCV hose. You can use a carb cleaner or propane to check suspected vacuum leak around the intake.
The important thing to keep in mind about vacuum leaks is that they have the most noticeable effect at idle. At part and full throttle, there is so much air entering the engine that a little extra air from a vacuum leak has a negligible effect.
If you have a scan tool, look at the Short Term Fuel Trim (STFT) and Long Term Fuel Trim (LTFT) values. Normal range is plus or minus 8. If the numbers are +10 or higher for STFT and LTFT, the engine is running LEAN. If you rev the engine to 1500 to 2000 rpm and hold it for a minute or so, and the STFT value drops back down to a more normal reading, it confirms the engine has a vacuum leak at idle. If the STFT value does not change much, the lean fuel condition is more likely a fuel delivery problem (weak fuel pump, restricted fuel filter, dirty fuel injectors or a leaky fuel pressure regulator) than a vacuum leak
SPONSORED LINKS
Wednesday, January 27th, 2010 AT 12:45 AM
