HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Contour
Steering
Steering Wheel
Symptoms
Shakes
SPONSORED LINKS
1995 Ford Contour
GOLDENCHIK0000
MEMBER
1995 FORD CONTOUR
1995 Ford Contour
I hit a block of hard packed ice snow and now my steering wheel shakes. Can you tell me what might be wrong?
Sunday, December 20th, 2009 AT 4:32 AM
MECHANIC
Hi there, you may have bent a steering rod, have the steering &suspension checked and get a wheel balance as well,
Mark (mhpautos)
SPONSORED LINKS
Sunday, December 20th, 2009 AT 4:52 AM
GOLDENCHIK0000
MEMBER
Thank you, I'm going to take it in today and have
it looked at.
Monday, December 21st, 2009 AT 5:27 AM
MECHANIC
Ok thats good, let me know if you need any more help.
Mark (mhpautos)
Monday, December 21st, 2009 AT 5:48 AM
Please
login
or
register
to post a reply.
Related Steering Wheel Shake Content
How To Tighten A Loose Steering Wheel On 1999 Ford...
Steering Wheel Itself Is Very Wobbly
Asked by
magicman567
1 ANSWER
1999
FORD CONTOUR
GUIDE
Steering Wheel Shaking
A steering wheel is designed to operate smoothly and not shake during the vehicle's operation. Shaking conditions can vary depending on vehicle speed, road conditions ...
1998 Ford Contour "growl"/vibration When...
I Have A 1998 Ford Contour, 4 Cylinder, Manual Transmission With 240,000 Miles On It. When There's Any Counterclockwise (left Turn)...
Asked by
gottahot1
1998
FORD CONTOUR
Power Steering Fluid
What Type Of Power Steering Fluid Do You Usefor A 1995 Ford Contour Gl
Asked by
jeffreydoss
1995
FORD CONTOUR
1999 Ford Contour Bent Steering Rod
Hi, I Had A Four Wheel Alignment Performed. When Leaving The Lot I Noticed Issues In Turning Left, And Steering Wheel Off Center To...
Asked by
JCORTIZ13
1999
FORD CONTOUR
1998 Ford Contour R/p Boot Leak
I Have A 1998 Ford Contour That Is Filling The Boot Between The R/p And Tie Rod End. This Model Has A Fluid Tube The Insets Into A Fitting...
Asked by
rdinle
1 ANSWER
1998
FORD CONTOUR
VIEW MORE
SPONSORED LINKS
Steering Wheel Removal
Airbag Removal - Drivers Side
Steering Intermediate Shafts Replacement
Online car repair manuals
