transmission change
FORD BRONCO
RPEDROZA
can i swap a bell housing from 1989bronco 5.0 standard with a 1987 ford p/u 6cyl standard the # on the 1989 is E9TA-BA and the 1987 is E8TA-JD If that means anything!
May 6, 2007 at 10:05 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
I doubt it, but call a junk yard and see if they will cross ref it for you.
May 7, 2007 at 2:26 PM
