[b]Hi, just wanted to sympathize with you, I have a 91 bronco, is yours carb, or fuel injected? Mine is fuel injected and I had that problem for a while, no fuel smelled like it was flooded even though no carburator. Turned over for days, would start. Replaced fuel pressure regulator, alt, new plugs, wires, dist cap and rotor, ERG valve. And battery. Still wouldn't start, finally had it towed to a shop. And $302 later. For my 302 engine. They replaced intake manifold gaskets, did oil change, and all new plugs again, cause they were all fouled. Runs better and has more power than it has ever had. But now of course if you look under Subject about steering. That's my new problem. Anyway. Don't know if anything helped, but I had to spend a lot to get my baby running.
Thursday, January 12th, 2006 AT 3:02 PM
