87 Bronco Rear End
1987 FORD BRONCO
MATTW0584
My rear end is shot in my bronco. the pinion bearings have been chewed up to nothing due to flakes of metal from the chipping pausi-trac clutches. I easily removed the internals from the axle and cleaned out all of the metal peices. when i went to put in my new ring and pinion with a new pausi, the gears were too tight together to move. i dont know what the problem is, i put everything back exactly how it was before. i even followed the chilton. Is there something special i have to do in order to make the gears fit?
Jun 17, 2007 at 11:25 AM
DONNY BRYSON
  • 13 POSTS
You can use the old paper methed to set the gears. They sould only crease the paper not cut it.
Jun 18, 2007 at 6:30 PM
