1996 Ford Bronco starting
1996 FORD BRONCO
163,000 MILES • V8 • 4WD • AUTOMATIC
HURT8000
the bronco starts when it wants to ,somedays i will turn it over and no fire,someday day it starts right up ,others days i hold down the ingition a little bit then it fires up ,please what could be the problem be
May 22, 2009 at 5:54 AM
  • 110,244 POSTS
It could be several things. However, I need you to check something so I know where to start. You need to check for fuel and spark to the engine when it doesn't start. Here are the "HOW TO's" for checking both. Let me know what you find.
https://www.2carpros.com/dia/test_fuel_pressure.htm
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Jun 4, 2009 at 3:33 PM
